KW36 jlink debug error
4,909件の閲覧回数
shawn_123
hello dear NXP engineer.
i am using jlink to debug with kw36 ble. the board is layout by our company. it is not the demo board,
i extend the jlink pin from the testpoint and connect with a ARM simulator purchase from internet, the version is arm11. detail info refer to attached pic.
firstly it can debug and run into breakpoint normally. after several times erase all operation. it no longer work normal now, pop up connect failure. i try to power on/off and plug in/out. the malfunction still exist.
try to unlock kinetis with jlink command 7.66 operation not ok.
why after i done the erase the jlink is not work normal. would you please give some idea and how to restore jlink debug.
4,886件の閲覧回数
nxf77486
Hello @shawn_123 ,
Thank you for contacting NXP support.  We have the following community post of clients with a similar issue, I will recommend to give a look into this solutions, and let me know if you find the useful I not so we can have an start  point to find a solution.
How to programm by Jlink Kinetis KE02?
programming kw40z by jlink
CMSIS-DAP and JLINK debuggers no longer working on IMXRT1050EVKB board
4,779件の閲覧回数
shawn_123
have fixed it thank you a lot!
