KW36 IQ method of BLE localisation
5,023 次查看
vigneshbalaji
Senior Contributor I
     I see that KW36 is supported for IQ localisation. Please give me some API documents or examples to realize this.
5 回复数
4,788 次查看
stephanie_m
Our current SDK contains APIs to capture IQ, nonetheless, you will need to develop your own examples with those API's.
The API's can be found at the following path.
              <installation path>\ middleware\wireless\framework_x.y.z\XCVR\MKW36Z
You can find the APIs to capture IQ in the dbg_ram_capture or the dma_capture files.
Estephania
4,788 次查看
vigneshbalaji
Is there any API documentation for IQ method API's?
4,788 次查看
stephanie_m
The APIs have they comments in the code, besides that, we do not have anything else on it yet on the topic.
We hope to have some document about it, nonetheless,  we do not have a date for its release yet.
Sorry for the inconveniences this might cause you.
Estephania
4,788 次查看
vigneshbalaji
    I am in the process of implementing IQ method in KW36. The comments on API's are not verbose enough. If you can give a basic information on the sequence of implementation. It will be of great help.
4,788 次查看
stephanie_m
Sorry for the inconveniences this might cause you, but currently that it's all the information we have available.
Estephania
