Overview
The Sub-GHz Remote Control Dimmer is a reference design which demonstrates the functionality of the MKW01Z128 MCU working in a custom IEEE 802.15.4 star network.
This reference design is focused on a home automation application where the user is able to control various RGB bulbs connected into a network using the KW01-RCD-RD board as a remote control. Controlled devices are USB-KW019032 boards, and each board simulates an RGB bulb in a GUI.
Sub-GHz technology has some advantages over other wireless technologies such less data traffic in its respective ISM band.
Features:
Documentation:
Schematics, Software, GUI and BSP:
Luis Burgos.
Hi!
Where can I download the source code of this reference design?
Hi Vu Nguyen,
Source code can now be found under "Software & Tools" tab from Sub-GHz Remote Control Dimmer webpage.
Luis Burgos.
