KV58: Acessing ITCM
2,468件の閲覧回数
lsrbigfoot
I plan to create a few data variables in ITCM (RAM Partition 2) to run a few memory tests on a MKV58F1M0VLQ24 MCU. Do I have to configure register(s) to enable ITCM? If yes then which register(s)?
タグ(4)
2,392件の閲覧回数
kerryzhou
Hi lsrbigfoot
  If you want to create a few data variables in ITCM, you just need to define the data in the related ITCM data range:
  You don't need to configure any other register.
You can try it on your side.
If you still have questions about it, please kindly let me know.
Kerry
2,393件の閲覧回数
kerryzhou
Hi lsrbigfoot
Kerry
2,392件の閲覧回数
lsrbigfoot
I tried accessing ITCM to do a few memory tests. Memory appears to be working. Thanks!
