KSZ8041NL Driver Support for K64 MCU
1,415件の閲覧回数
fshah30
Hi, I am working with PHY KSZ8041NL in RMII mode. I need driver to initialize the PHY and test TCP/IP communication with MCU. Kindly share link or details for KSZ8041NL driver. Thank you
タグ(1)
1,399件の閲覧回数
CarlosGarabito
Hi @fshah30
We only provide SDK support for the KSZ8081.  So, the only viable solution would be to investigate both datasheets for these differences and modify the code according to this model
Sorry for the inconvenience this may cause.
