A question about the Ethernet switch
1,252件の閲覧回数
Bryant11
I was thinking of adding wiring at least 4 Cat 7 Ethernet ports beside every outlet at least one per room, that I could think of where be a need for a wired Internet. Then all of those could be plugged in a Switch somewhere on our attic.
Do you think using a Wall Mounted Ethernet switch, like KSZ8895MQXIA, so you don't need to run the whole Device to attic Ethernet cable directly an efficient way to do it? Also will Ethernet ports degrade speeds vs direct Ethernet to Ethernet ports on Switch?
1,245件の閲覧回数
EdwinHz
Hi @Bryant11,
Considering that this is not a NXP device, I recommend you to contact the manufacturer directly for support on this part number. They should be able properly answer your inquiry.
BR,
Edwin.
