KM34P144M75SF0 16-bit resolution Conversion error
2,997 次查看
jun1
Hello.
"KM34P144M75SF0 Data Sheet: Technical Data Rev. 2, May 2015-3.4.1.2 16-bit ADC electrical characteristics"
The above data sheet does not mention the 16-bit conversion error of the ADC, but is it the same as 12-bit?
Thank you.
2,988 次查看
DanielRuvalcaba
Unfortunately we don’t have that information for the 16-bit mode. I’m sorry for the inconvenience this may cause.
Regards, Daniel.
2,984 次查看
jun1
Thank you for your answer. Does that mean that 16-bit mode isn't used much?
2,960 次查看
DanielRuvalcaba
I’m sorry for the inconvenience this might cause to you but the only information we have about this is that the information is not available.
Best regards, Daniel.
