KL82 QSPi
KL82 QSPi
2,631 次查看
gaobiao315
the application code now exceeds 128K(KL82Z128VMC7),How to download the application code into the plug-in flash。
4 回复数
2,490 次查看
kerryzhou
Hi jze duan,
   Do you want to put all the code to the QSPI and run from qspi, or just want to put some part of the code to the qspi flash, and still run from the internal flash?
  If you want to run from the qspi, you can refer to this document:
https://www.nxp.com/docs/en/user-guide/MBOOTQSPIUG.pdf
  If you just want to copy part of the code to the QSPI, you can refer to my attached code.
Wish it helps you!
kerry
2,490 次查看
gaobiao315
Hi Kerry Zhou,
Use your development board frdm-kl82z for debugging. According to the operations (MCU Bootloader QuadSPI User's Guide.pdf)in chapter 3 on the PDF file you provided, the prompt is as shown as the error.
2,490 次查看
kerryzhou
Hi Duan jz,
     configure-memory address is wrong, you are using 0X02000000, BUT you need to use 0X20000000
Please try it again.
Kerry
2,490 次查看
gaobiao315
希望大家能帮助解决一下,谢谢了!
