KL82 PWM on TPM1
KL82 PWM on TPM1
bopeng
I  configure PTB0 on kl82 as TPM1 channel0 and try to use it to generate PWM signal. But I fail to get PWM from that pin. But I successfully get PWM signal from TPM0 module.
I just wonder if there are other settings I need to take care if I want to use TPM1 to generate PWM.
IvanRuiz
Please make sure you are configuring PTB0 as output.
Ivan.
