KL26Z & RTC
KL26Z & RTC
2,828件の閲覧回数
simonatoumberto
I use
MKL26Z256VLL4 micro -  clock 8Mhz
I use  as RTC_CLKIN (pin PTC1) the output of pin PTC3
I set MGGIRCLK with souce 32KHz IRC
As you can see in Clock and RTC SET
I have a RTC time error - about 2 minutes x day
I see that PTC3 output a 32898 hz signal
instaead of waiting 32768 hz. (see RTCinput.jpg)
I have tried to adjust this signal
changing the value of  slow internal reference clock but no result
Can you give me some support?
Umberto
2,727件の閲覧回数
Hui_Ma
Please refer KL26 datasheet about the internal slow clock accuracy data:
If customer want more accuracy RTC clock, it need to use external 32.768KHz crystal or oscillator.
Thank you for the attention.
Ma Hui
