The KL25 Sub-Family Reference manual describes the DAC in Chapter 30.
Could someone please point me to where these sources are described - or what they are if they aren't.
Thanks!
Solved! Go to Solution.
Hi, Matthew
In KL25 reference manual chapter 3.2.2 "Analog reference options", you can find 12-bits DAC has two reference voltages for reference. One is VREFH and the other one is VDDA. If you use manual "KL25P80M48SF0RM", you can find on page 48.
Hope my reply can help you.
Best Regards
Paul
Thanks! Do I need to raise a ticket? The documentation, as it stands, isn't really helpful, and should certainly refer back to 3.2.2, rather than "see the module introduction," (which I interpret as 30.1) where no mention is made at all.
From practical purposes, since I'm actually trying to do something with a Freedom board, I believe these two lines are tied together anyway.
Hi, Matthew
It is no need to raise a ticket. Your idea is a good idea. It is a direction we need to improve. Thanks.
Best Regards
Paul
Hi, Matthew
Best Regards
Paul
