KEA64 A reset occurs when write flash
wenfengyao
When I write to the flash, the chip resets, even if the watchdog is turned off
The below is some code:
where is the error?
_Leo_
Hi Jacky Yao,
Thank you so much for your interest in our products and for using our community.
The reference manual has a chapter Flash Memory Module (FTMRH), which tells you the utilization of flash in detail, how to set the flash initialization, how must be the flash command write sequence, among others.
Please refer to the chapter Flash Memory Module (FTMRH) to understand how to perform flash.
Hope it helps you.
Have a nice day!
_Leo_
Hi Jacky Yao,
Hope it helps you.
Have a nice day!
