KEA sample code build error: ewl_c_noio.specs: No such file or directory
2,904 次查看
hns80
Senior Contributor I
I'm using S32DS for ARM v2.2 and downloaded the Quick Start Pack.
I imported Lab 1 and attempted to build it, but I get this error:
The system is expecting to find the arm_ewl2 directory under C:\NXP\S32DS_ARM\S32DS and it's not there.
Where can I get this library so I can build the quick start sample projects?
2,859 次查看
Celeste_Liu
Hello @hns80 ,
This issue can be resolved by replacing the "libraries support". Please refer to the following steps:
1. Right-click on this project and select "Properties".
2. Refer to the following screenshot and change "Libraries support" with "newlib no I/O (-specs=nosys.specs)". After the replacement, click "Apply" and then click "OK".
3. Clean the project and then build the project, and it can be successfully compiled.
Hope it can help you.
BRs,
Celeste
Note: If this post answers your question, please click the "ACCEPT AS SOLUTION" button. Thank you!
2,883 次查看
Celeste_Liu
Hello @hns80 ,
Thanks for your post.
I am wondering if you install the "S32 Design Studio for ARM v2.2 Update 2" package for your S32DS for ARM v2.2.
The downloading method is in the "6. Installation and Licensing" section of S32DS_ARM_Release_Notes_v2.2_up2.pdf.
I'm not sure if this is relevant. If you haven't installed it yet, you can give it a try.
If there are still problems after the installation, you can let me know.
BRs,
Celeste
2,875 次查看
hns80
Update 2 has trouble installing. Most of update 2 is related to S32K1 and MQX.
2,860 次查看
Celeste_Liu
Hello @hns80 ,
BRs,
Celeste
%3CLINGO-SUB%20id%3D%22lingo-sub-2063161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3EKEA%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9Aewl_c_noio.specs%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2063161%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%88%91%E6%AD%A3%E5%9C%A8%E4%BD%BF%E7%94%A8%20S32DS%20for%20ARM%20v2.2%20%E5%B9%B6%E4%B8%8B%E8%BD%BD%E4%BA%86%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E5%8C%85%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%AF%BC%E5%85%A5%E4%BA%86%E5%AE%9E%E9%AA%8C%E5%AE%A4%201%20%E5%B9%B6%E5%B0%9D%E8%AF%95%E6%9E%84%E5%BB%BA%E5%AE%83%EF%BC%8C%E4%BD%86%E5%87%BA%E7%8E%B0%E6%AD%A4%E9%94%99%E8%AF%AF%EF%BC%9A%3C%2FP%3E%3CP%3Eewl_c_noio.%E8%A7%84%E6%A0%BC%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FP%3E%3CP%3E%E7%B3%BB%E7%BB%9F%E5%B8%8C%E6%9C%9B%E5%9C%A8%20C%3A%5CNXP%5CS32DS_ARM%5CS32DS%20%E4%B8%8B%E6%89%BE%E5%88%B0%20arm_ewl2%20%E7%9B%AE%E5%BD%95%EF%BC%8C%E4%BD%86%E8%AF%A5%E7%9B%AE%E5%BD%95%E4%B8%8D%E5%AD%98%E5%9C%A8%E3%80%82%3C%2FP%3E%3CP%3E%E6%88%91%E5%8F%AF%E4%BB%A5%E5%9C%A8%E5%93%AA%E9%87%8C%E8%8E%B7%E5%BE%97%E8%BF%99%E4%B8%AA%E5%BA%93%E4%BB%A5%E4%BE%BF%E5%8F%AF%E4%BB%A5%E6%9E%84%E5%BB%BA%E5%BF%AB%E9%80%9F%E5%90%AF%E5%8A%A8%E7%A4%BA%E4%BE%8B%E9%A1%B9%E7%9B%AE%EF%BC%9F%3C%2FP%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E%3CLINGO-SUB%20id%3D%22lingo-sub-2064146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%E5%9B%9E%E5%A4%8D%EF%BC%9AKEA%20%E7%A4%BA%E4%BE%8B%E4%BB%A3%E7%A0%81%E6%9E%84%E5%BB%BA%E9%94%99%E8%AF%AF%EF%BC%9Aewl_c_noio.specs%EF%BC%9A%E6%B2%A1%E6%9C%89%E8%BF%99%E6%A0%B7%E7%9A%84%E6%96%87%E4%BB%B6%E6%88%96%E7%9B%AE%E5%BD%95%3C%2FLINGO-SUB%3E%3CLINGO-BODY%20id%3D%22lingo-body-2064146%22%20slang%3D%22en-US%22%20mode%3D%22CREATE%22%3E%3CP%3E%E6%9B%B4%E6%96%B0%202%20%E5%AE%89%E8%A3%85%E6%97%B6%E9%81%87%E5%88%B0%E9%97%AE%E9%A2%98%E3%80%82%E6%9B%B4%E6%96%B0%202%20%E7%9A%84%E5%A4%A7%E9%83%A8%E5%88%86%E5%86%85%E5%AE%B9%E4%B8%8E%20S32K1%20%E5%92%8C%20MQX%20%E7%9B%B8%E5%85%B3%E3%80%82%3C%2FP%3E%3CBR%20%2F%3E%3CBR%20%2F%3E%3C%2FLINGO-BODY%3E
