KEA cw11 global variable specific addr
1,664 次查看
sam_lgu
hi, everyone !
could anybody tell me how to define one global variable at specific addr ?
i tried "attribute" command, the ide told me it was ignored!
thanks
1,661 次查看
ErichStyger
Specialist I
I assume you are using gcc?
Then the following shall work:
https://mcuoneclipse.com/2012/11/01/defining-variables-at-absolute-addresses-with-gcc/
I hope this helps,
Erich
1,661 次查看
ErichStyger
Specialist I
I hope this helps,
Erich
