KE02 and KL02 micro to micro UART communication issues
1,012 次查看
umsankarkalluru
Hi Isaac Avila,
Thanks for spending time and providing the feedback on this.
The above experiment you did and code I have provided works communicating
from KE02 to KL02, but the actual problem was to communicate from KL02 to
KE02.
I repeated the experiment with custom board with KL02 processor and
FRDM-KE02Z board and i still face the issue of not communicating properly
from KL02 to KE02.
Please find the attached code which will communicate from KL02 to KE02,
Since I don't have KL02 freescale demo board , can you please run the
attached firmware on the above setup you have and let me know if you see
the correct bytes.
Thanks again for your help.
-Umasankar K
Original Attachment has been moved to: KE02_Test_02_06_2015.zip
Original Attachment has been moved to: KL02_Test_02_06_2015.zip
852 次查看
vicentegomez
Just to have it document, you solved it on
https://community.freescale.com/thread/356433
Vicente
