KE02 EEPROM program error FLASH_ERR_MGSTAT0
1,446 次查看
zoujiahao
Hello!
When I use the library function EEPROM_Program1Byte to write a byte to MKE02Z64VLD4's EEPROM, it can be successful at first two times after erase sectors, the third time has error FLASH_ERR_MGSTAT0. How to solve this problem?
1,286 次查看
zoujiahao
I found that it must erase the sector before using EEPROM_Program1Byte every time.
