KBI in KEA-128
KBI in KEA-128
vignesh_vb_7
   I am not able  to press 2 switches at the same time in KBI Interrupt in KEA-128.I am able to press it one by one only.what should i do to press 2 switches at the same time?
Paul_Tian
Hi, Vignesh
This depends on your key assignment. There are two KBI module on KEA128. So you can set these two keys to different KBI modules. Then you can use different interrupts and press two switches at the same time.
If you want to use the same KBI module on two switches, we cannot support such functions.
Hope my reply can help you.
Best RegardsPaul
