K70 DDR controller example?
3,899 次查看
crezyoz
Is there a bareboard or Processor expert DDR example for the K70 TOWER board anywhere?
3,247 次查看
crezyoz
I used one from the MQX libs. Seems to work but I am posting another question regarding MCG and DDR today. THE P.E. setup, and DDR in general, is way over my head. For the life of me I can not set up a driver from scratch.
4 回复数
3,247 次查看
LuisCasado
Have you tried the SC code. There are examples using DDR, for example the lcdc projects.
https://www.freescale.com/webapp/Download?colCode=KINETIS_120MHZ_SC&prodCode=K70_120&appType=license...
Luis
3,247 次查看
crezyoz
Thanks Luis, I did look through the samples.. didn't see any bareboard examples. I will check again! I Appreciate the response.
3,247 次查看
squadmcu
Hi Phil! Did you found what you need there?
3,248 次查看
crezyoz
