K66 with higher SRAM than 256KB
1,435件の閲覧回数
geovarghese
Is there a K66 part available with more than 256KB SRAM ? We are using MK66FN2M0VMD18 for our existing design. We need to have more memory for our new boards. It should be a dropin replacement for the current part.
1,321件の閲覧回数
xiangjun_rong
Hi, Geo,
Pls go to the website and check the K66 resource. As you see  the K66 series have at least 256K on-chip SRAM, at most 260KB SRAM. If you need more SRAM, I suggest you connect external SRAM on the FlexBUS.
ARM Cortex-M4|Kinetis K66 180 MHz 32-bit MCUs|NXP
Hope it can help you
Xiangjun rong
