K66 connecting SDRAM with 32bit data path
1,422 次查看
unknowncoder
I want to connect a SDRAM with a 32bit data path to the K66?
The user guide specifies that the K66 supports 32bit data path. But I noticed that the SDRAM data pins only support 16 bit data path.
Is it possible to use the Flexbus to compensate for the additional 16 data pins that are missing? If so how do I do this?
There is nothing in the user guide that specifies how to use a 32bit data path. Is it possible the user guide has mistakes?
标记 (3)
1,285 次查看
danielchen
Hi unknowncoder
K66 only supports 8-bit, 16-bit wide SDRAM blocks, not support 32-bit .
Daniel.
