K66 ADC routing
K66 ADC routing
kristiansolberg
Hi.
I designing a split ground high gain PCB and want the ADC to measure a buffered signal on the far en of the analog ground.
I attached two drawings of how I can route the signal to the ADC. I'm not too concerned about the resolution or quality of the measured signal. But I'm very concerned about contaminating the high gain / high impedance analog circuit.
What would be the best approach?
Hui_Ma
Please refer below application notes about ADC layout circuit design:
AN3962 PCB Layout Design Guide for Analog Applications
AN5032 Reference Circuit Design for a SAR ADC in SoC
[ADC.png] is better.
Wish it helps.
Mike
