K64F Mem allocation PE SDK
jeffking
I'm using a K64F PE and the SDK, how come I can't seem to allocate memory larger than a 100 bytes (probably not the upper limit), but I can't allocate 800 bytes.  I'm calling OS_Mem_alloc(800) and it returns NULL.  Any ideas what I forgot to do!?
Jeff.
Tags (2)
Jonathan_Iglesias
Hello, Jeff.
Can you send me the code, so I can see it, or explain  more detailed.
-Jonathan
jeffking
Hi Jonathan,
Thanks for getting back to me.  I was able to find a solution to this.  In case anyone else has this issue, the heap allocation was defaulted to a size of 0x0400 (1024 bytes), increasing this fixed my issue.
Thanks again
Jeff.
