K64 serial UART goes to sleep
1,176 次查看
roymessinger
In my custom K64 board I'm experiencing sleep mode in my UART after about an hour without communicating. Is this something concerned with the K64?
I did not write anything to the Power register.
If so, how do I disable it?
Roy
1,053 次查看
mjbcswitzerland
Specialist V
Roy
Can you explain what you mean with sleep mode?
The UART can be disabled (or it can stop working if you have SW bugs) but I don't know what you mean with it sleeping.
Mark
