spi is not showing in /dev directory in kinetis k70
sameerarvikar
I am follwing the below link to use spi in kinetis k70 having uclinux
http://www.emcraft.com/stm32f429discovery/accessing-spi-devices-in-linux
still i am not getting any spi device in /dev directory after running mdev -s command
spi device is registered as being seen in output of dmesg command
what might be the issue
thanks
