K64 and DP83848I Physical driver
pietrodicastri
Senior Contributor II
Good morning
I need to use the DP83848I physical for the ethernet in reduced mode. Is there a work already done for porting the LWIP to this chip?
Also suggest me a guideline for using this driver, just to  avoid to read too much just for this porting.
Happy new year...
Thank You all
Hui_Ma
Hi Pietro,
You can download the MQX software from here.
The DP83848I PHY driver located at default path: C:\Freescale\Freescale_MQX_4_1\mqx\source\io\enet\phy
I also attach the driver here (PHY Driver.7z) for your reference.
Thank you for the attention.
Have a nice day.
best regards,
Ma Hui
Hui_Ma
Freescale MQX provides DP83848I PHY driver, more detailed info, please check attached code.
Wish it helps.
Happy New Year!
best regards,
Ma Hui
pietrodicastri
Hello Ma Hui,
Thank you for assistance. I am happy to know the porting exists.
I don t see any attachment in the answer however. Maybe You can try again to send or
give me a link for the download.
Thank You
Pietro
Hui_Ma
Hi Pietro,
Have a nice day.
best regards,
Ma Hui
