K61 FS USB Controller to 4-Port Hub
1,318 次查看
ianandal
Has anyone been able to use the internal USB PHY on the K61 to act as a FS controller to a USB Hub?  The K61 detects the hub, but any devices connected to the downstream ports do not enumerate.
Ian
1,174 次查看
egoodii
Senior Contributor III
Do you have the 'Hub Class' enabled in your K61 build?
