K60 comparator input to output delay
2,193 次查看
bhh
Is there a specification for the propagation delay of the K60 comparator input to output (continuous mode)?  The reference manual calls this Tpd, but I haven't been able to find an actual value.
2,125 次查看
jeremyzhou
Hi Brian,
You can find this value in the datasheet, just as the Fig 1 shows.
Please check the datasheet through the link as below by yourself.
http://cache.freescale.com/files/32bit/doc/data_sheet/K60P100M100SF2V2.pdf?fasp=1&WT_TYPE=Data%20She...
Ping
2,125 次查看
bhh
I must have overlooked it before.  Thanks!
2,126 次查看
jeremyzhou
Hi Brian,
Ping
