K60 MMA7760 Accelerometer with I2C Protocol
1,949 次查看
broccolee
Does anybody know how to output the K60 tower board's accelerometer measurements via I2C Protocol and ProcessorExpert? I tried the example in codewarrior, debugged it, but it only returns descriptions, not measurements:
Any help, suggestions, guides on how to program this would be very much appreciated This is work related and time-sensitive.
Dao.
1,435 次查看
jeremyzhou
Hi Dao,
What a pity!
There are no demos that integrate K60 with MMA7760 for you, however I found a PE demo about KL25 usage another three-axis acccelerometer MMA8451Q.
The MMA84Q1 also support the I2C proposal and the demo is very worth to referring to.
I've attached the demo with the reply and please check it.
Ping
1,435 次查看
broccolee
Thanks for your help.
