K53 example code
K53 example code
K53 example code
The following file contains example code for usage of ADC, UART, DAC, GPIO, I2C, interrupts, MCG and timers for the k53 platform.
Regards.
添付
コメント
Hello!!
Excuse me, Could you please tell me how can the example code be compiled?
Thanks a lot!
Hi Sandra,
You simply import the example code into your CodeWarrior environment and compile it.
This might help you to get familiarized with the environment Freescale Kinetis K20 50Mhz Getting started with Codewarrior (V10.2) - Bareboard - YouTube
Manuel
評価なし
バージョン履歴
最終更新日:
‎10-27-2014 11:12 AM
更新者:
