K22/K64 HE-AAC audio codec
2,294 次查看
isaotakashima
Our customer would like to implement HE-AAC audio codec into their system using K22 or K64.
Could you please let us know NXP recommended HE-AAC audio codec.
Please reply as soon as possible.
Takashima
2,043 次查看
xiangjun_rong
Hi, Takashima,
Regarding your question, I have googled with the key words "HE-AAC", this is the explanation:
High-Efficiency Advanced Audio Coding - Wikipedia
The HE-AAC is  audio coding format, user can recover the HE-AAC data to PCM stream and output the PCM stream to codec via I2S data format via SAI interface. User can get the data with HE-AAC format via USB, SAI input module...
I think the codec device is an ADC or DAC, it can not receive HE-AAC data format directly usually, the Codec can only receive PCM data format with I2S protocol. The processor should recover to PCM from HE-AAC data stream.
the K64 and K22 have SAI interface, it can receive/transmit data via I2S protocol.
Hope it can help you
Xiangjun Rong
2,043 次查看
isaotakashima
Dear Xiangjun Rong
Thank you for your reply.
I found out below link regarding the AAC audio codec.
NXP - Partner Profile Information
This middle ware  seems to support HE-AAC with Kinetis-K series.
Could you please let us know feature of this middle ware.
Takashima
2,043 次查看
xiangjun_rong
Hi, Takashima
The Picustech Software is a third party company, I do not know the detail of the software, pls ask the Picustech Software directly.
Xiangjun Rong
