K21 Tamper question from AN4733
2,057 次查看
PHXFAE
Looking at AN4733 figure 1, it looks like the Tamper inputs are in the VBAT power domain but I don’t see a path to clear the key.  It doesn’t look like the tamper
pins can erase the key.  Are these pins only useful if main power is on?
1,788 次查看
Kan_Li
Hi Alex,
I just got the feedback, the expert told me there is some issue for Figure 1, which is not complete/accurate, but she assured me that the tamper inputs are connected to the key erase logic.
Hope that helps,
Kan
1,788 次查看
Kan_Li
Hi Alex,
I am checking with the DryIce expert, and will let you known when I have any more information.
Thanks for your patience!
Kan
