Is it possible to implement USB CDC using Kinetis SDK?
2,503 次查看
b51427
Hi everybody,
I can't find KSDK component for USB CDC class in the components library. Is it possible to implement USB CDC using KSDK?
标记 (5)
2,257 次查看
ivadorazinova
Hello Muhammad Saad Nawaz,
yes, it is possible. You can create own component with using Processor Expert Software: CDE|Freescale (Component Development Environment) and inheritance (e.g. you can heritage fsl_usb_descriptors component).
For more details please see
KDS_3.0.0\eclipse\ProcessorExpert\Help\CDE_Getting_Started_Guide.pdf
KDS_3.0.0\eclipse\ProcessorExpert\Help\CDE_RTOS_User_Guide.pdf
KDS_3.0.0\eclipse\ProcessorExpert\Help\CDE_User_Guide.pdf
I hope this helps,
Iva
2,257 次查看
b51427
Hi Iva,
I see fsl_usb_descriptors and fsl_usb_framework components in KSDK 1.2 but no device class component for USB CDC. Is there a already developed component available for it?
Saad
2,257 次查看
ivadorazinova
Hello Saad,
unfortunately no. There is no USB CDC support.
Have a nice day!
Iva
