Is CRC8 possible for CRC module?
kenansun
I'm trying to use the CRC module on my K60 MCU to generate CRC 8 code. I checked the methods in PEx and I found it not possible. It seems that the poly should be at least 16bit.
I also find a similar question here:
CRC_8 for Kinetis K60?
but no answers yet.
Does anybody know the answer? Please help me!
Many thanks!
Kenan
Kan_Li
Hi Kenan SUN,
I am sorry, but this module just supports CRC-16/32 . No support for 8 bit calculations.
Sorry for the inconvenience that has caused.
Have a great day!
B.R
Kan
tim_povall
8-bit CRC actually is possible with a 16 or 32-bit CRC module.
You can convert the 8-bit polynomial into 16-bit by shifting 8 bits to the left, and then to get a 8-bit result do the same to the resulting 16-bit CRC. Similarly, with 32-bit you would need to shift 24 bits to the left.
See my more detailed answer to a similar question here: S32DS CRC 8 calculation
Kan_Li
Hi Kenan SUN,
Have a great day!
B.R
Kan
