Interfacing FTDI FT232RL to K70 processor
1,948 次查看
chiranjeevn
Hi!
Instead of MC9S08JM60CLD IC as in Tower kit since it is quite logic complex and i think in my new board just i wanted to connect to terminal and debug ) in linux operating system? is it possible or any extra work associated to it.please assist me....
1,810 次查看
DavidS
Hi Chiranjeev,
You are correct adding the debugger interface from the Tower to your customer design is a complex way to go.
FTDI is a solution.
Freescale has a solution as well:
http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=USB2SER&fsrch=1&sr=3&pageNum=1
The USB2SER solution has example board reference design, drivers, and silicon to use.
David
1,810 次查看
DavidS
Hi Chiranjeev,
FTDI is a solution.
David
