In MKW41Z512VHT4 can we use both zigbee & bluetooth sametime?
1,066 次查看
chanduec007
I'm planning to use MKW41Z512VHT4 in our IOT application, regarding that i have below quires:
1). Can i use both zigbee & bluetooth same time in our application, is this module will support.
2). What is the maximum distance both zigbee & bluetooth will support, to increase the distance do i need to add power amplifier, can you please suggest the best one for this module.
Chandrashekar
942 次查看
mario_castaneda
Hi Chandra,
The KW41z supports Thread 802.15.4 & BLE. This MCU will be launch this october, this information is avaliable to alpha customer. Please contact your local sales for more information.
Best Regards
Mario
