I2C on K66F
I2C on K66F
1,676 次查看
a8Chcx
I am using K66F MCU for my controller.
My question: What is the voltage level allowed for I2C pins? Can I use the pull-up resisters to 5VDC on SDA and SCL? Or I have to use 3.3VDC for pull-up?
Christie
1,647 次查看
Miguel04
Hi @a8Chcx
I recommend you to use a pullup to 3.3V, the FRDM-K66 uses 3.3V pullups with the ACCELEROMETER AND MAGNETOMETER internal sensors.
Best Regards, Miguel.
1,648 次查看
Miguel04
Hi @a8Chcx
