I USED MK20DX128VLH5 FREEDOM BOARD
1,221 次查看
dhanalakshmisre
IN THAT HOW TO USE 6_bit DAC,SEND SAMPLE CODE...
1,166 次查看
jeremyzhou
I'd highly recommend that you can refer to the 32.11 Digital-to-analog converter block diagram section for details.
The section illustrates the steps of using the 6-bit DAC
Hope it helps.
Ping
