How use DSP in Kinetis K40X256 MCU?
4,170件の閲覧回数
Magnetron
How can I use DSP in Kinetis K40 MCU?
2,556件の閲覧回数
anthony_huereca
All the DSP instructions and documentation can be found on the ARM website.
Here is the latest reference manual for the M4 that has the DSP instructions with cycle times: http://infocenter.arm.com/help/topic/com.arm.doc.ddi0439c/DDI0439C_cortex_m4_r0p1_trm.pdf
And the assembly instructions are described in detail in this document: http://infocenter.arm.com/help/topic/com.arm.doc.dui0553a/DUI0553A_cortex_m4_dgug.pdf
You can also find the ARM CMSIS (Cortex Microcontroller Software Interface Standard) DSP 2.0 Library at http://www.onarm.com/
Anthony
2,557件の閲覧回数
anthony_huereca
Anthony
