How to uninstall KDS updates manually?
2,662件の閲覧回数
darnaiadam
Hi, I bumped into a problem with KDS updates. I installed KDS 3.0 on a Linux based computer (14.04 LTS, Ubuntu distribution). After that I tried to update the software components, as debugger, SDK and Processor Expert. Everything went fine, but after a restart the KDS popped up an error message, that said: Processor Expert configuration file not found. I realized that couldn't uninstall components in KDS, so my question is that how can I uninstall the whole KDS and components manually? Thanks
タグ(2)
2,497件の閲覧回数
BlackNight
You can uninstall plugins this way: https://mcuoneclipse.com/2012/06/10/uninstalling-eclipse-plugins/
There is as well https://mcuoneclipse.com/2015/08/08/revert-an-eclipse-update-installation/
Other than that, you could remove the installation folder if you want to get rid of everything.
I hope this helps,
Erich
3 返答(返信)
2,498件の閲覧回数
BlackNight
I hope this helps,
Erich
2,497件の閲覧回数
darnaiadam
Finally I could set the workspace correctly with the newest KDS version 3.2. The older development environments were not able to uninstall components(the button was inactive). The second link you shared will be useful, thank you very much!
2,497件の閲覧回数
darnaiadam
* sorry, KDS is removed, but the somponents like Processor Expert isnt.
