How to trace PE_ISR() for MK60 MCU
2,169件の閲覧回数
rabbitz
I have an CodeWarrior peoject with PE generated code, it some time trigger PE_ISR() and hang, I would like to trace the reason and fix it.
Is there suggestion how to trace it?
Sam
3 返答(返信)
2,039件の閲覧回数
BlackNight
Hi Sam,
You can enable 'own handler for every interrupt', so you know which interrupt is firing.
See Oh my! An Interrupt… | MCU on Eclipse
I hope this helps,
Erich
2,039件の閲覧回数
rabbitz
Hi Erich,
It is Hard_Fault,
How many conditions can cause this fault?
Sam
2,039件の閲覧回数
BlackNight
Hi Sam,
most likely it is a misaligned access, an access to a NULL pointer or accessing a peripheral which is not clocked/powered.
Here are a few articles how to debug the reason for the hard fault:
Debugging Hard Faults on ARM Cortex-M
Debugging ARM Cortex-M Hard Faults with GDB Custom Command
A Processor Expert Component to Help with Hard Faults
For the last one with that Processor Expert component (this is what I use with my Processor Expert projects), you can find it on SourceForge:
https://sourceforge.net/projects/mcuoneclipse/files/PEx%20Components/
how to install: McuOnEclipse Releases on SourceForge
I hope this helps,
Erich
