How to select the right ARM micro
838 次查看
robinator
Hello all. I need help selecting the correct microprocessor to use. I like Freescale Kinetis micros.
I need to be able to do canbus, USB, RS232 communications.
I also need a 2 x 12bit ADCs minimum and it would be nice if it had a 2 DACs but they would have to be at least 16bit. Also, I need the smallest package possible.
Does anyone have any experience with this type of application? Thanks.
753 次查看
ankur_kala
Hi Robert,
try with the solution advisor : http://www.freescale.com/webapp/sps/site/prod_summary.jsp?code=SOLUTION_ADVISOR&fsrch=1&sr=1&pageNum...
you can select the filters as per your requirement.
