How to know the microcontroller restart reason
3,585件の閲覧回数
sudhanshumehta
We are using MK221M controller.
RTOS MQX4.2
I need to know the restart reason of microcontroller on every reboot.
Example: Microcontroller can restart due to Watchdog, power cycle etc.
Can you please suggest me way to do that?
Sudhanshu
3,548件の閲覧回数
bobpaddock
Senior Contributor IV
I've not used this part, does it have a Reset Control Module (RCM)?
Look for something like System Reset Status Register 0 (RCM_SRS0 and SRS1) etc.
Some times there are also 'sticky' copies. Better to use those results if available.
4 返答(返信)
3,532件の閲覧回数
sudhanshumehta
 Yes RCM->SRS0, RCM->SRS1 are the registers. this is complete detail. bobpaddock was right. you can read printf ("\r\n Restart reason code %.02x %.02x", RCM->SRS0, RCM->SRS1);
3,549件の閲覧回数
bobpaddock
3,531件の閲覧回数
sudhanshumehta
for more details my reply is below
3,559件の閲覧回数
danielchen
Hi @sudhanshumehta
I would suggest you ask our partner, Embedded Access, for this question.
https://embedded-access.com/
