How to know that how much stack size occupied by my tasks
1,255 次查看
utsavikalpesh
I am working on Code warrior v10.2 and of MQX v4.0.
I want to know that how much stack size occupied by my task.
In my current task
1,110 次查看
ivadorazinova
Hi Utsavi Kalpesh Bharuchwala,
there is a special tool for task stack size information called Task Aware Debugging Plug-in (TAD).
The tool provides you information about Stack Base, Stack Limit, Stack Used, % Used and Overflow to specific task.
Is it available for your version, CodeWarrior v10.2.
You can look e.g. http://cache.freescale.com/files/soft_dev_tools/doc/support_info/FSL_MQX_Getting_Started.pdf page 15
I hope it helps,
Iva
1,110 次查看
utsavikalpesh
Hi Iva
I am sorry, By mistaken this Discussion was posted 2 times.I have already got the ans from How to know that how many stack size is occupied by threads
utsavi
1,110 次查看
ivadorazinova
Hi Utsavi Kalpesh Bharuchwala.
That is ok. I did not notice it.
The main thing is that you solved the problem.
Iva
