How to interface a sensor with KW41z?
1,258 次查看
joshisr
We are trying to interface a water level detection sensor with KW41z, are there any sample examples that can help do it? there isn't enough data here on interfacing using this end device. Also our plan is to form a THREAD network, and connect every end device to different sensors and transmit incoming data to our assigned border router. Our purpose is to show how thread works in the first place.
1,207 次查看
stephanie_m
It will depend on your sensor's way of communication, the freedom board has some sensors on it and there are examples in the SDK interfacing with those.
Which kind of sensor are you planning to use?
Reagrds,
Estephania
