How to get started with RTOS
3,235 次查看
punitkumar
Till now, I've only did baremetal projects and so not familiar with any rtos or embedded Linux.
Can someone please guide me on how to get started learning rtos/embedded Linux?
I'm thinking of getting started with FreeRTOS, will it be good to start?
Thanks & regards
Punit Kumar
3,021 次查看
mrharmonsr
I recommend the book "“µC/OS-II: The Real-Time Kernel, 2nd Edition" for learning about RTOSs.  I believe you
can download it here:   https://www.micrium.com/download/µcos-ii-the-real-time-kernel-2nd-edition/
After reading the book, you will be able to see how FreeRTOS and other RTOSs implement the RTOS concepts.
FreeRTOS is a great place to start.
Using an RTOS is much simpler than using embedded Linux.
3,021 次查看
punitkumar
Thanks larryharmon
