How to flash a program with CAN
2,010 次查看
T2
I want to write the program created by MCUXpresso to the target board via CAN.
It would be helpful if you could tell me what kind of method is available.
As a result of my research, I arrived at the MCU Bootloader.
But it's difficult for me to understand.
It would be helpful if you could tell me if there is any other way.
* I have the following boards.
FRDM-KW36, TWR-KE18F, TWR-KV46F150M
Best regards.
2 回复数
1,997 次查看
jingpan
1,983 次查看
T2
Hi Jing,
Thank you for your advice!
I will try it with reference to the materials I was taught.
Best Regard,
Takagi
