How to create lib files with codewarrior
4,237 次查看
jimtom
标记 (1)
3,954 次查看
BlackNight
6 回复数
3,954 次查看
BlackNight
with MCU10.3 there is library option available in the wizard.
Otherwise: see
Creating and using Libraries with ARM gcc and Eclipse | MCU on Eclipse
I hope this helps.
3,954 次查看
jimtom
not found library option available in the wizard
3,954 次查看
BlackNight
Have you selected a Kinetis device?
It is available for me both in MCU10.4 and MCU10.3.
Maybe you are using an older version?
3,954 次查看
jimtom
I use MCU10.3.
3,954 次查看
jimtom
3,955 次查看
BlackNight
Select 'Bareboard project' and then it is here:
http://mcuoneclipse.files.wordpress.com/2013/02/library-creation.png
