How to Generate ms delay in TWR-K20D72M board?
1,183 次查看
bhavinmaru
I am Using TWR-K20D72M board i downloaded various sample codes from nxp site.i tried to generate delay of ms using lptmr library but i can't generate delay.i have requirement to generate ms delay in my code so please give me suggestion that how i can generate ms delay.if you have code that can generate ms delay so please give me.
Thank You
Bhavin
1,060 次查看
Hello Bhavin,
Which IDE do you used ? If KDS or CW, you can directly use the PE , add PIT  component ,
then configure one 1ms interrupt.
If not , you can find one PIT or FTM configure demo , check how to configure the interrupt .
Hope it helps
Alice
