How many core cycles take a 32 byte / 16 byte = 16 byte division instruction on a MKL17Z128?
ソリューションへジャンプ
2,612件の閲覧回数
MAPC
Senior Contributor I
Can anybody tell me how many core cycles does a 32 byte / 16 bytes = 16 byte division instruction take on a MKL17Z128?
How to optimize the compiler (both in KDS and in MCUXpresso) in order to produce the minimal set of assembly instructions for that?
I haven't found any specific information about that, not even in ARM Cortex M0 Plus Manual.
Marco Coelho
DFAE - Siletec Eletronica
2,461件の閲覧回数
kerryzhou
Hi Marco,
   Actually, the core cycles take a 32 byte / 16 bytes is determined by your IDE code.
   I think you can write a small example about 32 byte / 16 bytes in the IDE you are using, then debug the code, check the according asm code.
   After you get the according asm code, please refer to my attached document: Cortex-M0+ Technical Reference Manual.pdf.
  Page 26, chapter 3.3 Instruction set summary.
   You can find each assembler cycles, then just according to table 3-1, to calculate your 32 byte / 16 bytes asm cycles.
   Take care, higher optimization will caused smaller ASM code.
  Please try it on your side.
If you still have question about it, please let me know!
Kerry
2,462件の閲覧回数
kerryzhou
Hi Marco,
Kerry
