How does IEHOST in USBx_ADDINFO get cleared in the K20 USBOTG module?
1,092 次查看
wre
Hi.  After configuring the K20 USBOTG module to be a device the IEHOST bit is still set.  What is required to clear IEHOST?
Thanks.
标签 (2)
标记 (4)
985 次查看
albertovargas
Hi Bill,
This register is used during the initialization of the module and it can't be changed on the fly.
If you need to change it on the fly, check USB On-The-Go or Duall Role configuration for it
985 次查看
wre
Thanks for the reply.  I understand that it can not be cleared (to indicate Device) directly.  I'm trying to understand what I'm missing in my configuration of the USBOTG module that keeps IEHOST set.  In other words, after I configure the module I would expect IEHOST to be cleared but it isn't.  My assumption is that I'm missing something in the configuration but I don't know what.
Bill
